JDPenn Newbie
| Posted: Dec 19 2015 at 4:57pm | IP Logged
My 2002 Frontier XE with a VG33e v 6 has developed a miss that comes and
goes. I had it checked and a code P0301 came up misfiring cylinder one.
checked the plug, shows good ohm tested the plug wire,shows good.
compression checked, shows good,noid tested the injector harness, shows
good. Injector was considered to be the issue. Replaced the injector. Now the
miss is intermittent. It will idle smooth a few moments then miss a few times,
cycling between smooth and rough.
__________________ thanks
| Posted: Dec 19 2015 at 8:25pm | IP Logged
I don't know but it might be time to clean the MAF.
What does the Intake filter look like?
Good Luck.. Don S..
