Posted: May 13 2016 at 7:43pm | IP Logged
Almost any cooling coil will work unless you're doing HD towing.
The trick is don't put it in front of the A/C core and the radiator... Why add heat to them???
Find a spot away from the mufflers under the bed.
Have a good one.. Don S..
