Ricks Newbie
| Posted: Apr 07 2017 at 3:42pm | IP Logged
I just installed a 3 inch lift kit on my Fronttier Pro-4X. It was a 3 inch
polyurethane spacer on the front struts and lift blocks below the rear
leaf springs and longer shocks. Pretty straight forward. However, now
when I drive I notice a small vibration at slower speed's. It seems to go
away at speeds over 40. If you've ever had too large of tires on a
vehicle, you would notice a rubbing sound when you make a sharp
turn. That's what it sounds and feels like but not quite as rough. I
double checked all the connections and everything looks good. Not
sure what might have caused this. Any ideas to point me in the right
direction would be appreciated.
| Posted: Apr 07 2017 at 5:22pm | IP Logged
U-joints????
Ricks Newbie
| Posted: Apr 08 2017 at 6:50pm | IP Logged
The problem was the rear lift blocks. They are tapered...one end is
about 1/2 inch taller than the other. Tallest end must be toward the
rear. Mine were toward the front. I turned them around and the
vibration disappeared. Found the solution on YouTube.
