Rubble Moderator Group
Online Status: Offline Posts: 392
| Posted: Nov 14 2022 at 9:16pm | IP Logged
engineer21237 wrote:
Hello,
I am trying to source a 2002 Nissan frontier 3.3 L engine
VG33E dual valve spring. I was able to get the outer and
inner length of the spring. However the OEM parts are
discontinued from Nissan. I was unable to find a general
duel spring that fits the inner and outer length. I
was able to source a new spring however it is in Canada
and shipping is quite expensive. Is there another duel
valve spring that is comparable off another Nissan model?
Thank you for any help with this matter.
Spring dimensions
<table style="width: 100%"><t><tr><td>OUTER</td><td >51.2
mm (2.016 in)</td></tr><tr><td>INNER</td> ;<td>44.1 mm
(1.736 in)</td></tr></t></table> |
Engineer,
Go to this site: https://www.nissanpartsdeal.com/
Put in your vin # and get the correct part # if it is
listed. Then search on the Web useing the correct part
#, to see if anybody has the part; Also check on amazon
and Ebay as well. Never know who might have it.
If you've allready done the above then that's all I've
got for now.
Good Luck,
