Frontier Off Road 4x2/4x4
Subject Topic: 2016 4x2 Frontier 2.5 gas LSD dif f??? Post ReplyPost New Topic
tico1998
Costa Rica
Posted: Dec 03 2024 at 8:07am | IP Logged Quote tico1998
hello I'm new here. Excuse my English.
I recently bought a 2016 4x2 Frontier series S king cab 2.5
lt. gasoline. Checking for a noise, my mechanic told me it
had kind of diff lock, because the 2 wheels spinned in the
same direction when lifted.   I took it to a slipperty
spot, put it on 1st gear and push down the gas pedal
firmly.   The result was 2 even tracks, I repeated with the
Dinamyc Control off and again I got 2 even tracks.
So, does it really have a LSD diff?? If so, I'd like to
change the oil, is it 75W-90?
Back to Top View tico1998's Profile Search for other posts by tico1998
Rubble
Posted: Dec 03 2024 at 10:17pm | IP Logged Quote Rubble
2.5
it
the
the
If You are haveing problem's with the Rear End,, I would
take it to Nissan and let them check it out..
The Lubricant to use is Specified in Your Owner's Manual.
The Differential Spec's will be described in Your Owner's
Manual and/or the Genuine Nissan Service Manual which you
can download by doing a Google Search.
Be sure to Check the Level of the Current Lubricant
before doing anymore driveing is my advice.
