Rubble Moderator Group
Online Status: Offline Posts: 366
| Posted: Dec 22 2024 at 5:53pm | IP Logged
jdbrowne69 wrote:
Went to pick up my trailer (which I
hadn't used in quite
some time) and the brake lights would only flash, when I
pressed the pedal. As I got the same result at the
converter, I replaced it. Same result. Any ideas as to
what my issue might be? |
My Suspicion is somewhere in the Wireing.
If You don't know how to check your Wireing,, I would
take it to Good Mechanic or Nissan and see if they can
figure it out.
When I last used my Utility Trailer, I noticed that the
Plastic covering the connectors on Trailer Pigtail had
Dry Rotted. Something like that happening can cause a
Short, so I need to get a New Pigtail or fabricate some
more plastic to repair the pigtail.
Rat's are know to chew on Wireing, as well as Wireing
Insulation Plastic Cracking, Chafeing, Etc, that can
cause a Short Circuit.
When You Find the problem, Don't just patch it, Fix it
Right the 1st Time...
