Subject Topic: 03 Frontier compressor switch Post ReplyPost New Topic
Vintage Racer
U.S. - Alabama
Posted: Mar 26 2026 at 8:03pm | IP Logged Quote Vintage Racer
I have an 03 Frontier that has a bad compressor switch in
the evaporator. The replacement switch is a two wire but
mine is a three wire. Can I retrofit the two wire version
into my Frontier or is there an alternate switch that can
be used?
Two wire
replacement
Thanks!
Back to Top View Vintage Racer's Profile Search for other posts by Vintage Racer
Rubble
Posted: Mar 27 2026 at 10:09am | IP Logged Quote Rubble
be used?
Two wire
replacement
Thanks!
Go To https://www.nissanpartsdeal.com/
Put in your Vin and get the Exact Nissan Part #. Then Google
to see if anybody has the Genuine Nissan part.
Check Amazon, Ebay, Walmart.com and Your Local Nissan
Parts Department.
If You can't find the Exact Genuine Nissan Part, Then Take it to
The Nissan Service Dept or A Professional that service's Nissan
Air Condition system's, is my advice.
Don't experiment with a part that is Not the Exact Genuine
Nissan part Especially with the Air Conditioner System. Might
cause another problem and be more expensive in the end.
