Subject Topic: new member with an oil leak Post ReplyPost New Topic
slipjoint
Posted: Sep 25 2006 at 3:58pm | IP Logged Quote slipjoint
I have lurked here before for mod ideas and basic maintenance. Fortunately I have had zero problems with my 02 Frontier 4x4 crew cab 3.3......until now! She is pushing 110k and I was about to change timing belt when she developed a pretty bad oil leak from rear of engine. I am going to put her in the air and get a good look around oil pan and check close around the valve covers. Most of the oil seems to be around where transmission bolts up (makes me think rear main)
I also have an 87 Hardbody ext cab 4x4 5sp 4 banger with 230k and I have pulled tranny a couple of times, as well as the head.
Are their any other oil leak suspects that I should check?
If I have to seperate transmission and engine, should I pull completely and replace anything on it ? (I also planned on ujoints at this point)
I love my trucks and I want to get this oil leak resolved this weekend.
Thanks in advance, and fire away with any tips or ideas.
Back to Top View slipjoint's Profile Search for other posts by slipjoint
hintonl
Posted: Sep 25 2006 at 4:32pm | IP Logged Quote hintonl
The rear main seal is leaking it happens a lot on the 3.3L you have to pull the Transmission out easy seal to replace just a major PITA to get to.
2K Crew Cab Converted to 4X4
slipjoint
Posted: Sep 28 2006 at 12:54pm | IP Logged Quote slipjoint
Thanks
You are right about PITA that transmission and trasfer case are huge and there is a lot of "stuff" in the way.
If all goes well I will post back with results.
02 Frontier Crew Cab 4x4
hintonl
Posted: Sep 28 2006 at 1:13pm | IP Logged Quote hintonl
what I do is remove the transfer case first then the transmission it make it a little easyer to handle also I removed all of the cross members makes it easy to slide the transmission back.
