| Posted: Nov 13 2006 at 3:13am | IP Logged
that all depends on what you are going for as far as ride quality too, the frontier is a truck, fully boxed frame, just like it's bigger brother the Titan, and also has the same rear end as the titan i believe with the towing package, some might be able to answer that better than i can, i do know that since i believe 05 or this year, the sport trac (i.e. explorers) are less trucks as they have less ground clearance, and have gone to independent suspension all the way around and it also rides smoother, the frontier has a stronger engine b/w the two 6 cylinders and also more towing capacity b/w the two 6 cylinders (btw both are 4.0L V6's), Ford does offer the 4.6L V8 in the XLT and Limited models which has 292HP, about 25 more than the 06 Frontier. Payload capacities are virtually b/w the two and only with the Sport Trac V8 option do you have about 300 more lbs towing capacity. gas mileage b/w the 2 is slightly better listed no teh frontier but only by 1 mpg, I rode in a new sport trac this weekend that my gf was test driving and while it is nice...i prefer nissan and liked by brother's 05 frontier better, tho the inside of the sport trac has gotten nicer than it used to be as far as styling.
also keep in mind if you need more bed space, the 07 LE frontier crew cab is now being offered with a long bed option like the older ones has the option for but i believe it's only on the LE model
