| Posted: Feb 20 2008 at 6:15pm | IP Logged
Shiftless,
What you're seeing on my LE is a 'SNUGtop XTR' that is manufactured especially for the Frontier and factory painted to the factory color of the truck. It's made for the 05-07 model years, but believe the 08s are the same size and style. There are other styles and manufacturers - some less expensive that mine.
http://www.alohatoppers.com
I purchased it locally at a place called 'Aloha Toppers' and they did all the labor of installation. The whole package was about $2200.00 plus shipping to HI installed. I've been told that you can shave $500-700 off of that price by purchasing it wholesale in the lower 48.
The two biggest benefits to the cap is: 1. You can haul items taller than the bed sidewalls easily and securely. (Rails are still available) and 2. If you need to haul something longer than 5', it's easy to secure it above. (at least with the XTR.)
It does change the lines of the truck (+/-), It increases the gas milage about 1.5 mpg (+) and the extra weight (~100 lbs) seems to balance the trucks front/back ratio. (+) I still like the lines of the Frontier with a tonneau cover, but convienience won over esctetics.
There are different 'grades' of caps - from the thin plastic type to very solid fiberglass. My last cap was the former; functional but noisy. This one is fiberglass and I've never heard it rattle, rumble or squeak.
Options built into the cap that are worth looking at are a dome light and a hanger bar for clothes. Also worth the few extra dollars is a front window that folds down to allow cleaning of it - and the trucks back window.
Let me (us) know what you decide... And post a picture.
R/ Bob
__________________ Bob S.
2007 Red Brawn CC LE
Waipio Gentry HI
Old friends; they mean much more to me than the new friends; because they can see where you are; and they know where you've been!
