         breckenrick Newbie
           | Posted: Apr 21 2006 at 8:22am | IP Logged
Hey all, new owner of 2000 Frontier Crew Cab 4x4.  Has the bed extender and stock bed liner.  Any ideas on hauling 2 bikes in the bed. Are there any Nissan or after market racks available?  I've got a roof rack, and could haul up there but prefer to haul down low. Other ideas?
Thanks.  Breckenrick
         Frontyfan Senior Member
           | Posted: Apr 21 2006 at 10:18pm | IP Logged
well there are a lot of diff options out there...some
pretty nifty bike rikes, some that are trailer hitch mount, as well as
inbed and other roof rack type options..but if you don't have a hitch
and don't want to run them up top as you said, there are some options
for hauling in bed, if you do have a hitch that broadens your choices
but, most of the hitch mount ones are fairly similar from what i've
seen, maybe someone else can expand on that if they see it differently.
below is a few links of some places that offer diff setups, some are
general links and you would have to look for application specific (i.e.
your model and year) hope this helps
http://www.autoanything.com/bike-racks/10A50163.aspx
  http://www.jcwhitney.com/autoparts/Search?catalogId=10101&am p;am p;storeId=10101&sku=bike+racks
Also go to www.AZtrucks.com and look up topline bed bike rack for a bed option
www.therackwarehouse.com
www.orsracksdirect.com/bike-racks.html
         Keepers Newbie
           | Posted: Sep 01 2006 at 6:00pm | IP Logged
Does anyone know if the Thule Xsporster will work with the Frontier's unitrack, I did see an adapter for the Toota Tacoma, has anyone used this rack on a Frontier Crew Cab?
         mwippern Newbie
 Online Status: Offline Posts: 27
           | Posted: Sep 05 2006 at 1:05pm | IP Logged
There is a rack called the Thule BedRider. I can never find it on the Thule website, but I bought one from a bike store. And you can find loads of them online.
Basically it's an extendable bar that clamps into position across the top of the bed behind the cab. It has a locking clamp on one side that holds the rack in TIGHT. Comes with two fork clamps (one for each bike).
I can fit either two road bikes or 2 mountain bikes on that rack without the need for my bed extender.
Good Point : It costs about $150
Bad Point : Has no built-in bike lock, so you need a cable lock.
           | Posted: Sep 05 2006 at 11:48pm | IP Logged
does that one also collapse slightly or slide in to fit in the cab when not using it say behind the rear seat in the CC. looks like an interesting rack, simple but effective.
         nismoladd Newbie
           | Posted: Sep 06 2006 at 5:01pm | IP Logged
Are there any quick release bike clamps that can be used in the bed tracks on the new fronties? I just got a Nismo '06 and don't want to drill holes in the bed to install my old cleats. If anyone knows if they make cleats to hold bikes that you can put into and remove from the tracts the information would be much appreciated.
         murph_fan51 Groupie
 Online Status: Offline Posts: 57
           | Posted: Sep 07 2006 at 6:39am | IP Logged
You could get a Tuff Deck fitted and lie the bikes on the side inside the bed.
         mwippern Newbie
           | Posted: Sep 11 2006 at 7:49am | IP Logged
The Bike Rack that I have pictured above does not need to be drilled. The bar is telescopic, so you extend it until it is a firm fit, and then the locking clamp further tightens it.
It can be removed very quickly but I have not tried storing it behind the CC rear seats. There seems to be enough space back there above the jack, so it may be a perfect place for it.
         mwippern Newbie
           | Posted: Sep 11 2006 at 8:47am | IP Logged
So I was just looking for a Frontier Accessory and stumbled across these:
 http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=P ROD&Product_Code=RAW-3
Picture shows them in the side rail, but they must also work in the bed rail, musn't they?
I am not sure who makes them, but so many people think that the utili-track system would be perfect for this. I wish Nissan would sell a cleat specifically for putting a bike on.
         Nerve58 Newbie
           | Posted: Nov 08 2006 at 10:41pm | IP Logged
Delta makes a bike rack that is basically a large "U" shape, with traps attached to the uprights of the "U".  The tops of the "U" are strapped over the tailgate to the bottom of the "U".
I am trying to find the link I used to purchase said rack.   Works great, not much rub on tailgate.
  __________________ N. Narvais
