davidjbrady Senior Member
| Posted: Jul 19 2013 at 5:49pm | IP Logged
Hello, I will hitting the 60K mark in a few months, was planning on doing an ATF change. Any items to consider?
I hear there is a filter in the tranny but it can be tricky to take out?
Thanks,
David
| Posted: Jul 20 2013 at 8:06pm | IP Logged
It is a metal screen that could be cleaned w/ brake parts
cleaner in the trans. or you could have the systemm
flushed. Be sure to use the correct fluid.
| Posted: Jul 20 2013 at 9:47pm | IP Logged
Save the old fluid to measure so you’ll know how much
(about) new to put back in… for starters.
Good luck.. Don S..
| Posted: Jul 21 2013 at 6:33pm | IP Logged
Just to make sure, I leave the filter in the tranny and spray brake clean, is that correct?
I will need a new pan gasket and plug gasket as well?
Or is silicone better?
Thanks!
| Posted: Jul 21 2013 at 8:02pm | IP Logged
Yes to leaving the filter in the trans. NO to silicone-get
a new gasket for the pan, don't worry about the plug
washer.
tumbleweed Newbie
| Posted: Sep 06 2013 at 10:52am | IP Logged
Thanks,
David
What kind of fluid do you plan to use?
__________________ Tom from Eastern Oregon
2012 Frontier Pro-4X
