jgreenjr Senior Member
| Posted: Aug 06 2013 at 8:54pm | IP Logged
Sorry i been away for good while been busy get our house remodle! all done now all i need get done is my ham radio back in the house !
Tonight i just joined car club at our local club i been enter my nissan last 2 years ,the truck got 3rd last year this year 2nd and now time join the club !
__________________ Jackie
A Proud owner of
2003 Nissan Frontier XE
4 cyl.
4x2
auto.
KA24DE
Stereo:Kenwood KDC BT648U
Ham radio since 2001 N4MJG
Tullahoma Tenn
| Posted: Aug 06 2013 at 10:14pm | IP Logged
Glad your back!!!
I still have all my Ham gear including a 2kw 6 band
amplifier but slipped up and let my general ticket expire
<snif><snif>
Have a good one.. Don S..
dannyg Senior Member
| Posted: Aug 07 2013 at 2:02pm | IP Logged
last i was on here gas was 2.50 a gallon hope everyone is having fun
06 frontier 4.0 auto
Boomer Senior Member
| Posted: Aug 08 2013 at 7:19am | IP Logged
Am I old? I remeber buying 6 gallons of Mobil regular in TN in 1971 for $1. Hi test was 5 gallons for $1. Cheapest gas I ever saw.
| Posted: Aug 08 2013 at 11:23am | IP Logged
Back when I started buying gasoline there were still
quite a few gas pumps that you hand pumped the gas up
into a five gallon glass on top of the pump then drained
it into your tank. Then you went in (Deep Rock service
station) and paid them the 85 cents for the five gallons
and another 17 cents for a pack of Luck Stripes. That was
before the Korean War.
Speaking of the ‘Good Old Days’ many cars didn’t have
fuel pumps and some didn’t have a water (coolant) pump,
and you cranked open the windshield for air conditioning.
Starting the engine could break your arm, but you never
had to check the brake fluid and the turn signal could
get Arthritis and also get arrested for flashing.
Good luck.. Don S..
| Posted: Aug 09 2013 at 7:23am | IP Logged
I remeber cars with "270" air conditioning and owned a few. Open two windows and go 70 mph! Also I am sure you remember the high beam switch as a button on the floor that you operated with your left foot, the vent doors that opened when you pulled knob on the dash and even vent windows. I once drove a car with cable, not hydraulic, brakes. (And even cars with hydraulic brakes had drum brakes on all four wheels.) That was a real thrill.
And remeber "Kendall, the 2000 mile oil." That was a big deal that you could go up to 2000 miles on an oil fill! And with leaded gas, you had to replace the exhaust system every few years as it would rot out from the lead acids. And then there was the 50,000 mile carb and valve job where the carb had to be rebuilt and the head pulled so the valves and valve seats could be ground. It was a real story if you could get a car to 100,000 miles in the good old days. Steering wheels were huge as most cars wieghed a lot and had no power steering and so you needed the leverage of a large steering wheel to turn the car. Many of us attached those little knobs to the wheel to get the extra leverage they provided.
And there were the oil bath air filters where the air going into the engine passed over a pool of motor oil in the aircleaner. And blowby was directed into a breather tube that allowed all of that stuff to blow right into the atmosphere.
Ah, the good old days! May they never come again....W. C. Fields
| Posted: Aug 09 2013 at 11:07am | IP Logged
the aircleaner.
I was fixin’ to go on a trip when the dipper switch (a UK
term) failed on my ‘47 Ford. The parts houses were closed
so I installed a rheostat on the bright beam circuit. It
worked fantastic. And I used the Kendal 2000!
How about this… You were supposed to do a ‘lube job’,
change the oil in the ‘oil bath’ air cleaner, change the
engine oil & filter (some were rag filters) and check the
transmission and differential every 1000 miles. The ‘lube
job’ was greasing up to 20 grease zerks and checking the
brake fluid that was under the floor-boards. Older cars
had flat headed grease zerks instead of the round tipped
later versions. Good tires lasted 15,000 miles. The
’modern’ three lane highways helped speed up traffic.
Chevy’s had fiber timming gears that needed replacement
every 60,000 and shimmed rod bearings that scooped up oil
in the crank-case and needed to be adjusted (re-shimmed)
in 10 to 20 thousand miles. VW,s needed valve adjustments
every 15,000 miles. Some Plymouths circulated engine oil
in the transmission. I drove a 1926 Franklin that had a
wooden framed sheet metal covered body and an air cooled
engine. Who the devil dreamed up the up-draft
carburetors?
Service Stations would wash dry, clean the glass inside
and out, and vacuum your car for a dollar (Cadillac’s
cost extra). They would check and air up the tires and
wash the windshield while pumping your gas. They would
Break down your flat tires and patch the inter-tubes for
50 cents.
Have a good one if you can remember to do it.. Don S..
| Posted: Aug 09 2013 at 11:24am | IP Logged
Oh, yes. And the points and plugs every 10,000 miles as the plugs got lead fouled and the little fiber block on the points wore down and changed the dwell angle. A big thing to own when I was a young man was a dwell meter..then you did not have to set the points with a feeler gauge!
You are right about tires. Less expensive rayon or nylon bias ply tires only went 10,000 miles...you put new ones on every year. I remember in the 60's when glass belted tires showed up. And then radials in the late 60's and early 70's....nobody believed at first that they would go 40,000 miles. I also remember having tubes in the tires. They ended up in the swimming hole after they got numerous patches on them.
And metal dashboards, no seat belts and a steering wheel post that would puncture your chest if you got hit head on. The guys in the back seat at least had the driver and front seat passenger as their "air bag in a collision.
And now we are having 9 speed auto trannies. What happened to the old GM Power glide tranny that had two speeds and only shifted once? Or the three speed manual with the shifter on the steering column? And buy a vehicle from a Japanese company? Are you crazy?
Times are different, my friend. I now have a Japanese truck (Nissan Fronty), a german car (VW Passat diesel) and an American car that is made no more (Saturn L300 coupe).
| Posted: Aug 19 2013 at 12:39pm | IP Logged
don`t forget soild lifter cams that needed adjustments
now today a us name plate is more forgin than a nissan BTW my dad still has his dwell/engine tune its called came from sears in the late 60s i think
davidjbrady Senior Member
| Posted: Aug 19 2013 at 2:10pm | IP Logged
I too remember dwell guages as well as timing lights with no advance. I had a timing light that you had to poke a hole in the #1 cylinder wire to get the spark reading, before they had the clip on sensors. I am 40 years old, and recall being the only one in my high school auto shop being able to adjust the dwell on a 1972 small block Chevy that had 2 points. Today many folks don't even know what a distributor cap is, think they were extinct in 2000 or so... My father's truck had tube type split rims..another extinct feature...
