jgreenjr Senior Member
| Posted: Sep 03 2013 at 9:32pm | IP Logged
I got question i just have new trottlebody put in back in march now tires are spinning! i took it to dealer could not make it do it ! is this normal as anyone have same issue as mine?
Some days it spins somedays it spin a little abit and once a awhile 4 or 5 times work day it don't do that.
I drive normal speed i don't jack rabbit or go high speed excpet highway doing 70.i took it to my best mech. it very sen. what happen was someone strip the treads on old trottlebody it don't do that like that. But new does do it ! it's drive me and my girlfriend up wall hearing tires spinning !
__________________ Jackie
A Proud owner of
2003 Nissan Frontier XE
4 cyl.
4x2
auto.
KA24DE
Stereo:Kenwood KDC BT648U
Ham radio since 2001 N4MJG
Tullahoma Tenn
| Posted: Sep 03 2013 at 9:39pm | IP Logged
Well that sounds really good... as long as the wheels are
spinning at the same RPM as the tires...
73s.. Don S..
| Posted: Sep 03 2013 at 9:45pm | IP Logged
73s.. Don S.. |
Is it that normal for it for do to do that? thats never done that the old trottlebody. i had this truck since 2009 i never could understand why new trottle body make tires spinning !
A Proud owner of
4 cyl.
4x2
auto.
KA24DE
Tullahoma Tenn
| Posted: Sep 04 2013 at 9:27am | IP Logged
It is possible the linkage between the throttle body and
the accelerator peddle is different. This could cause a
quicker response time or more power than at the old peddle
setting.
If the mass flow sensor in in the throttle body that could
also make it act different.
Is the new throttle body a genuine new Nissan part?
Have a cool one or a six pack.. Don S..
| Posted: Sep 04 2013 at 11:44am | IP Logged
throttle body and
could cause a
at the old peddle
setting.
body that could
Nissan part?
Don,
I have order from dealer and they are the
one installed the throttle body plus make
me wandering if belts are wore out and
cause make the noise ?
A Proud owner of
4 cyl.
4x2
auto.
KA24DE
Tullahoma Tenn
| Posted: Sep 04 2013 at 4:53pm | IP Logged
me and my friend of mine we both check belts ,the belt are good as new atfer i got off the spinning about 30 mins ago it didin't do it this morning but it did 30 mins ago ! very short spin it is very odd . maybe it will take time for stop spin the wheels the old thorttle never spin it wheel untill the new was install by nissan dealer install brand new thorttle this year very thouchy gas paddle make it spin too easy lol !
nothing wrong with belt all good !!
A Proud owner of
4 cyl.
4x2
auto.
KA24DE
Tullahoma Tenn
| Posted: Sep 05 2013 at 10:03am | IP Logged
It can still be the belts making the noise. The belts
can get hardened with age and the contact surfaces of the
pulleys can get polished smooth so the belts can slip and
make the noise.
You can try sanding both surfaces with 3M wet or dry #400
sand paper. They make a spray to stop the noise but I
once heard something bad about it and forgot what it was.
I got grease in my hair and every thing slips my mind…
Good Luck.. Don S..
Boomer Senior Member
| Posted: Sep 06 2013 at 9:24am | IP Logged
A good thing for noisy belts is to put a few dabs of SILICONE GREASE (not petroleum grease) on the ribbed or drive side of the belt. If the squeak persists, it is not the belts. This trick will cure even the most stubborn belt noises, even on new belts.
| Posted: Sep 06 2013 at 9:45am | IP Logged
durning work week sometime it will do it other time it don't ! but it sure do love do it on weekend lol
A Proud owner of
4 cyl.
4x2
auto.
KA24DE
Tullahoma Tenn
| Posted: Sep 06 2013 at 12:41pm | IP Logged
I find my paper work by dealer from nissan,the throttlebody was been done at march 8,2013 cost me $640.00
also they replaced throttlebody assy and reset idle and i went on head order the gasket throttle got new stud since other one was striped by last owner those where replaced and chamber also !
To me the old throttle never spin it wheels untill the new throttle been replaced now spin it wheels, they tell me nothing to worry about but it drive me nut and i hate for police stop me because wheels are spinning even very lite step on gas it does !! i do not understand all this which make no sence to me
A Proud owner of
4 cyl.
4x2
auto.
KA24DE
Tullahoma Tenn
