Subject Topic: New 4cyl 5 sp 4X2 Frontier Post ReplyPost New Topic
Talltights
Posted: Apr 09 2016 at 5:21am | IP Logged Quote Talltights
I am looking to buy a new truck. Light duty, personal
use. Is the 4cyl reliable, is it underpowered even
without towing? Can the engine last over 100K mi?
Back to Top View Talltights's Profile Search for other posts by Talltights
Posted: Apr 09 2016 at 11:43am | IP Logged Quote lakota
Welcome...
Personally I would not trade my '99 3.3 King Cab for anything, any brand.
You might look at buying a late model Hard-Body 95 - 97 and rebuild it for less than a new one. They were tough! I liked the '95 3.3 Hard-Body King Cab that I had.
Four bangers are OK in the flat lands and the 3.3's are a little under powered in the Colorado Rockies.
Good Luck.. Don S..
Posted: Apr 09 2016 at 2:43pm | IP Logged Quote frontierguy
Lakota, Have you driven a 4.0 Frontier? Lot's of power,
much better brakes, better fuel economy, better ride,
what more could you ask for(except a lower
price$$$$$??????
Rubble
Posted: Apr 09 2016 at 7:27pm | IP Logged Quote Rubble
TL,
I had a '93 KC Hardbody with the 2.4,, and it did fine,, but alway's wished that It had a stronger engine.
After driveing it for 20 year's & 176K Mile's it was still running good, but decided it was about time to get a New Truck.
Compared MPG between the 2.5 and the 4.0 Frontier,, and the difference wasn't very much.
The 2.5 is rated to pull about 3500 lbs, and the 4.0 is rated to pull 6500 lbs, so that alone tell's you how much stronger the 4.0 is than the 2.5.
I got a '13 Frontier 4.0 KC, AT, 2wd, and it really has a lot more power than the 2.4 '93.
The Current Frontier's are quiet a bit heavier than the hardbody that I had.  The 2.5 does have more horsepower and rated to pull more than the '93.  You'll just have to go drive both and compare them.
IMO the 4.0 is the way to go, but if MPG matter's to you,, just go real easy on the skinny pedal.  I'm averageing 20.6 MPG in Mixed Driveing with my '13 4.0  .
I've read many post's of the 4.0 going past 300K Miles.  I haven't read anything about the 2.5 haveing problem's either,, and would expect to get about the same out of it,, if it is taken good care of, and not abused.  That goes for the 4.0 as well;  take care of it, and don't abuse it.
Rereading your question, I think you'll be more happy with the 4.0 Frontier.
HTH and Good Luck
Posted: Apr 09 2016 at 7:37pm | IP Logged Quote lakota
I'm staying with My '99 because...
First... My '99 KC has key start. It won't run without a key. In 15 years I had to spend about $15 bucks total to Keep it running!
Second... I got burned by one 4x4 that had a D-44A.
Third... My '95 Hard body KC was a hair small so I got my '99 it was just right. A Suburban won't fit in my garage.
Have a good one.. Don S..
BTW... My '99 Frontier is kinda like my good working Windows XP.
My Windows 7 pro Sucks and
So I ain't down-grading to Windows 10!
