| Posted: Jul 30 2006 at 11:13pm | IP Logged
When the size is kept the roughly the same, not much is effected other than performance. It's when you change the OVERALL diameter that speed and mileage changes.
For differences between stock rim, and a larger rim. Performance mainly. A 20" rim with low profile tires will handle better, due to less flex and roll in the sidewall. BUT your chances of damaging a rim, especially a 20", JUMP WAY HIGH. Due to the fact that the stock sidewall gives a cushion between the rim and the road. But a low pro does not offer any proctection against potholes and such. Also weight can come into play, and put a strain on the drivetrain. A 20" rim with low pro tires COULD be heavier than a stock setup. It all depends upon how much the rim weighs.
