| Posted: Dec 03 2007 at 1:24pm | IP Logged
wvuwoodsman;
Welcome to the group!
... The clutch start cancel system was designed for off road rock climbing. Where, in 4-low range, you turn off the engine and use the starter to lowly climb up and over a large obstacle. This is done to prevent excessive wear of the clutch and throw-out bearing. It may not work unless the truck is in 4-low. Automatic transmissions rule off road! Been there, done that for many years.
Laws such as the use of corn ethanol are driving up the cost of living (have you been to the grocery store lately) without driving up wages. This equates to a lower standard of living (but not in China) thanks to Agro-lobbyists and corrupt and ill-informed lawmakers.
