| Posted: Jan 09 2009 at 4:02pm | IP Logged
Howdy! I am the original owner of a 2002 Nissan Frontier SE V6, 2WD. The truck has 119k and has been the most reliable vehicle I have yet to own.
Other than routine maintenance (most of which I have done myself in the last couple of years) the only "problem" I have had with it had to do with a high pressure air conditioning hose. This hose was not covered under my extended warranty and cost me about $800 to have repaired at the dealership. But hey, it gets hot in South Texas! I can not complain about the $800 since that is the only big problem i've experienced in seven years.
I've posted in another area of this site about a possible knock sensor and/or oxygen sensor problem, so if you have any knowledge to share I would greatly appreciate it!
__________________ 2002 Nissan Frontier SE-V6 (VG33), Crew Cab, 2WD, A/T, MFG 08/2002
