Mobile Audio / Electronics
Subject Topic: factory stereo Post ReplyPost New Topic
05nismoking
U.S. - Virginia
Posted: Oct 08 2007 at 2:13pm | IP Logged Quote 05nismoking
does anyone know if the nissan 6cd changer (non-bose) will work as a replacement in my 05 kc 4 speaker with the cheap factory single disc cd player. if so is there anything special about the wiring?
Back to Top View 05nismoking's Profile Search for other posts by 05nismoking
jers
Canada
Posted: Mar 04 2008 at 3:26pm | IP Logged Quote jers
Do you mean the standalone internally amped one, one or the Rockford Fosgate one?
If the stand alone unit, it will plug right in, you will have to order different mounting brackets from the dealer for the 6 disc. They are only a couple dollars. If not, the unit sticks out too much and you can' get the dash back together. I just confirmed that myself and now have to wait for the brackets to arrive.
If you mean the Rockford Fosgate unit, it's not worth the hassle. That setup needs an the factory amp, and for the money spent, unless you really want the oem look, you would do better after market.
Back to Top View jers's Profile Search for other posts by jers
