jfurgeson Newbie
| Posted: Jan 19 2008 at 5:53pm | IP Logged
I'm installing the Sirius satellite radio tuner box in my 05 Frontier. Wondering if anybody could suggest a good location to mount the little tuner box. Preferrably somewhere up in the dash...I'm trying to maintain a clean install
solidhex Newbie
| Posted: Jan 23 2008 at 9:26pm | IP Logged
dude, i just got a tuner and an interface to install with an aftermarket reciever. i havn't installed yet, but i was poking around under the dash and i think i found a spot. as long as you have enough cable, i think you can mount it to the left of the brake/clutch pedals. there is a metal panel that looks "furred" out from the exterior wall of the truck. as long as the screws you use are short enough, i think it'd be a good mounting place, out of the way and easy to access in case of problems.
jfurgeson Newbie
| Posted: Jan 24 2008 at 12:19am | IP Logged
Thanks for the suggestion. I ended up finding a little nook in behind the glove box since I brought the antenna wire up on the passenger side. It's pretty easy to get at if you take the glove box out, and that's not too hard. I'm going to be installing a bluetooth box as well so I'll keep that other location in mind.
solidhex Newbie
| Posted: Jan 26 2008 at 11:01am | IP Logged
right on dude, nice work. i ended up mounting the tuner and interface on the drivers side, they fit great, and when installing them the gas pedal is a great headrest.
