Mobile Audio / Electronics
Subject Topic: Satalite Radio Post ReplyPost New Topic
Russell
Posted: Jun 18 2008 at 10:56am | IP Logged Quote Russell
I own a 2008 Frontier with a stock radio and cd player. Questions are,,,,, is there a aux jack in the back of this unit to plug my satalite radio into. Does anybody have a picture of the back of one of these radio/cd players, or on info how to remove.
Thanks in advance
Back to Top View Russell's Profile Search for other posts by Russell
sailor_lou
U.S. - Connecticut
Posted: Jun 27 2008 at 11:42am | IP Logged Quote sailor_lou
I have the stock single CD radio and it does not have any provisions for an aux input.  The removal is quite simple.  Carefully pop out the small tray on the dash (above the radio) and you will find a single phillips head screw.  Remove the screw and then you can pull the trim piece around the radio out.  The entire piece, including the heater controls, comes straight out and there is sufficient slack in the cables to turn it out of the way to gain access to the radio mounting screws.  The radio has a single electrical connector and one antenna connection on the back.
My satellite radio has an electronic switch that goes into the antenna cable and is hardwired into the satellite receiver.  It uses the standard antenna connnectors (I believe they are RCA connectors), which unfortuantely did not mate up with the Nissan antenna cable so additional adapters were required.  Sorry, no pics.
Lou
08 Frontiier KC NISMO, 6 Speed, Majestic Blue
Back to Top View sailor_lou's Profile Search for other posts by sailor_lou
Russell
Posted: Jul 01 2008 at 11:57pm | IP Logged Quote Russell
Thanks man
