| Posted: Sep 10 2007 at 2:17pm | IP Logged
Hello, I had the dealership install a towing package when I got my 06 fronty. I looked under the rear of the truck at the plug and it appears to be fully installed with all the wires in the harness. My question is in regard to hooking up a brake controller to the factory harness.
Can anyone tell me where the plug that I need to connect the controller to is located? I found a plug under the dash that has the following wires, orange, brown, red, green.
Unfortunately I didn't get the pigtail to connect the factory harness to the brake controller as I hear many people did, if I would have then this would be a no brainer. TIA, Dan
