jermo537 Newbie
Posted: Jul 23 2007 at 8:57pm | IP Logged
my 01 frontier wont start. drove just fine night before but when i came out in the morning it just clicks a few times and doesnt turn over. the lights seem bright and everything which doesnt seem like a battery problem. what i did anyways was replace the battery and starter and still same problem. im really new to trucks because i have owned hondas all my life. checked fuses and all the simple stuff. me and my roomates think its something electrical or something with the ignition. does this resemble an ignition switch problem by chance? any info would be great....thanks!
CRDLIBERTY Newbie
Posted: Jul 23 2007 at 10:16pm | IP Logged
Im looking into purchasing a 2000 crew cab right now. I have owned a 99 tacoma i found the wall mart battery i was using inferior to make starter copper windings move. I ended up spending $400 to have them diag work. I think the real problem was trash marts battery.
jermo537 Newbie
Posted: Jul 23 2007 at 10:25pm | IP Logged
CRDLIBERTY wrote:
Im looking into purchasing a 2000 crew cab right now. I have owned a 99 tacoma i found the wall mart battery i was using inferior to make starter copper windings move. I ended up spending $400 to have them diag work. I think the real problem was trash marts battery. |
trash mart lol the battery that is in there def is not from walmart and the new one i bought was from checkers...it prob is not much better than walmart either but this prob definitely lies with the electric or ignition...ill try to explain what it does better...when i turn the key to start it it just click a few times and all the lights die out...while the key sits on the on position the lights should be on if the battery is charged...well after trying to start it everything dies...i turn the key off and back to the on position (not start it) and the lights come on and are bright as day...it seems like something shorts out when i try to start it and kills the lights until i turn the ignition to the off position...freakin weird man!
Posted: Jul 24 2007 at 7:05am | IP Logged
well what you describe is the classic case of a dead battery. The lights will come on decently, but there isn't enough juice to turn the motor over. There could possibly be a short with your starter relay. Under the hood on the driver's side there should be a electrical box with some fuses and relays. The starter relay should be in there. Swap it out temporarly with one that you know works. Like your headlights (provided they are the same design)
hintonl Senior Member
Posted: Jul 24 2007 at 11:20am | IP Logged
take a hammer tap on the starter see if it will turn over then Had the same thing happen to me the solenoid would stick sometimes.
jermo537 Newbie
Posted: Jul 24 2007 at 2:31pm | IP Logged
hintonl wrote:
take a hammer tap on the starter see if it will turn over then Had the same thing happen to me the solenoid would stick sometimes. |
well i bought a new starter and installed it and it does the exact same thing...bought a battery and installed it and does the exact same thing...it doesnt go to start the car at all it just like clicks, shorts out and all the lights die like the battery completely died...but i turn the key off and turn it to the on position and all the lights are bright as day!! what the?!?!?
Posted: Jul 24 2007 at 3:51pm | IP Logged
Check the negitive battery cable some times they can get all Corroded(sp) up on the inside make sure you have a good ground.
jermo537 Newbie
Posted: Jul 24 2007 at 4:42pm | IP Logged
well i just called my roadside service to have it towed....i dont wanna mess with it anymore and will pay for the problem to disappear lol god i hope it wasnt a damn battery cable because i paid 100$ for the towing...thanks guys for your help and i will post the solution
Posted: Jul 25 2007 at 7:24am | IP Logged
Sounds to me like the system is shorting out to ground somewhere, maybe in the ignition switch itself. Oh well, you'll find out here pretty soon.
jermo537 Newbie
Posted: Jul 25 2007 at 1:58pm | IP Logged
well hintonl is the man! spent 60 bucks to tow it for the auto repair place to tell me they cleaned my negative battery cable im kinda angry about that because i thought i cleaned it good enough myself...but then again my truck has been getting 15 MPG highway which i thought is terrible so i told them to change the spark plugs while it was there...thanks again guys hintonl nailed it!
