Crosscheck Newbie
| Posted: Nov 19 2007 at 3:18pm | IP Logged
I have a 2002 Frontier S/C. The supercharger has a rattle-type of noise in it. At first, I thought one of the idler bearings for the Serpentine belt were going bad but, after listening closer with a stethoscope, I found the noise coming from the 'Charger. Is this a common issue and what is the fix?
Thank you.
nbaldanza Newbie
| Posted: May 22 2008 at 1:54pm | IP Logged
I HAVE AN 02 ALSO AND MINE IS MAKING THE SAME NOISE I TOOK IT TO A TRUSTED MECHANIC AND HE SAID IT SOUNDS LIKE IT NEED OIL IN THE SUPERCHARGER I CALLED THE NISSAN DEALERSHIP AND THEY SAID THE MOTOR OIL RUNS IN TO THE SUPERCHARGER AND LUBRICATES IT SO I AM GOING HOME TONIGHT AND TRYING TO BREAK THE PLUG LOOSE ON THE SUPERCHARGER AND CHECK FOR MY SELF
nbaldanza Newbie
| Posted: May 23 2008 at 3:04pm | IP Logged
FOUND OUT THAT THE MOTOR DOES NOT SUPPLY OIL TO THE SUPERCHARGER YOU HAVE TO UNDO THE PLUG AND FILL IT UP YOUR SELF THE GUY I TALKED TO AT THE NISSAN DEALER SHIP SAID THE WOULD PUT A HEAVY THICK OIT IN IT LIKE 80W-90 OR CLOSE TO THAT AND THAT SHOULD STOP THE LOUD NOISE YOU HEAR
hsckris Groupie
| Posted: May 25 2008 at 9:18am | IP Logged
Its also possible that you could need a rebuild. These superchargers have been known to need servicing at as little as 80k.
03 Ford Focus ZX3.
Chris6744 Senior Member
| Posted: May 28 2008 at 11:25am | IP Logged
try to service it. superchargers take a very special oil that you need to buy at nissan. wear gloves because if you get the oil on ur hands it smells for days
__________________ 2007 nismo 4x4 cc (red)
3IN LIFT,TOYO MT'S,
Boise ,ID
| Posted: Jun 10 2008 at 8:25pm | IP Logged
Thank you. |
lassification: ECO4-011 Reference: NTB04-083 Date: July 14, 2004 2001-2004 FRONTIER AND XTERRA; SUPERCHARGER NOISE AT IDLE AND LACK OF POWER APPLIED VEHICLES: 2001 - 2004 Frontier (D22) equipped with supercharger. 2002 - 2004 Xterra (WD22) equipped with supercharger.
IF YOU CONFIRM:
The supercharger makes a rattle/grinding type noise at Idle, and |
The engine has reduced power while driving. |
ACTION:
| a. |
Review the supercharger information in this bulletin. |
| b. |
If your incident is not caused by "park knock" as described in this bulletin:
Go to ASIST for further diagnostic information | | NOTE :DO NOT REPLACE THE SUPERCHARGER FOR A SPARK KNOCK INCIDENT.
SUPERCHARGER INFORMATION
Premium fuel is required
The Supercharged (VG33) V-6 engine used in the 2001-2004 D22 Frontier and the 2002-2004 WD22 Xterra requires Premium Fuel. |
If premium fuel is not used, the engine may experience "park knock" during acceleration or under heavy loads. |
If spark knock is detected by the "knock sensor", the ECM will put the supercharger into bypass (fail-safe) mode. |
The supercharger will make a rattle/grinding type noise at idle when it is in "fail safe". |
Also, the engine will have reduced power if driven in "fail safe". |
Supercharger Bypass Valve
The bypass valve limits boost pressure from the supercharger when the system is in fail-safe. |
< =":Zoom('/all/PRO~V60286547~C39887~R0~OB0~P2R0H~N/0/86372027 /89377758/89377833/110844307/
34853741/
34850750/42063452/119615480/108883910/108646547',
1, 1088, 692, 'ZoomWin', CAPTION108646547, 'NONE', HIGHNONE);" method="post"> < value="Zoom" ="submit">> |
< =":SizedForPrint('/all/PRO~V60286547~C39887~R0~OB0~P2R0X~
N/0/86372027/89377758/89377833/110844307/34853741/34850750/
42063452/119615480/108883910/108646547', 1, 650, 413, 'ZoomWin', CAPTION108646547, 'NONE', HIGHNONE);" method="post"> < value="Sized for Print" ="submit">> | |
In fail-safe, the internal bypass valve will remain mostly closed (see Figure 1). |
After the key is turned OFF the ECM will reset and restore the boost solenoid function.
The bypass valve will function normally, and the rattle/grinding type noise will be eliminated. |
34853741/34850750/42063452/119615480/108883910/107283044', 1, 1072, 121, 'ZoomWin', CAPTION107283044, 'NONE', HIGHNONE);" method="post"> < value="Zoom" ="submit">> | |
osccean23 Newbie
| Posted: Jul 01 2009 at 2:34pm | IP Logged
i have the same problem with o2 nissan frontier sc it was making rattling noise it was under warranty so they replced it i asked the dealer about the oil they say they dont sell it i dont know about gear oil however thres a member in our group knows where to buy it ,chris6744 let us know chris , have great day fellas
__________________ riding ridin
ergomoto Newbie
Online Status: Offline Posts: 26
| Posted: Feb 22 2010 at 2:41am | IP Logged
I see this is an old thread with occasional posts. I too now have the same "failed bearing" noise from my '03 SC, and am away on a trip with the truck. I've always run High Octane and have not changed the pulley size. Curious about this oil topic -if only to get the truck home. Assumed it was going to take a rebuild and some luck to get the chance to do it at home.
Mark S/C
__________________ 1965 Datsun 1300 520 Pickup
2003 Nissan Frontier S/C SE Crew Cab Std Bed
Is that what you wanted it to look like?
