Subject Topic: Electrical Problems Post ReplyPost New Topic
j mcpheezy
U.S. - Louisiana
Posted: Feb 12 2008 at 3:56pm | IP Logged Quote j mcpheezy
 I got a hand full of problems....
dome lights wont work...
cruise control shuts off when i use turn signal...
when i use the clicker to lock and unlock doors, horn wont beep and lights wont flash...
i seriously doubt someone else has the same problems but hopefully someone can help........thanks
'04 CrewCab XE
   :::MODS:::
- K&N Cold Air
- Flowmaster Exhaust
- Airaid Poweraid T.B.S.
- 5% tint
- Black Headlights
Back to Top View j mcpheezy's Profile Search for other posts by j mcpheezy
thedave360
U.S. - Louisiana
Posted: Feb 12 2008 at 9:47pm | IP Logged Quote thedave360
What I would do in your situation, is get a Haynes manual for the truck and look at all the electrical diagrams for each of these problems.  These things must have something in common. Some wires may be shorting out, or just close enough to interfere with each other.
Good luck!
By the way, where at you live in Louisiana?
Shift_Your own gears
Baton Rouge, LA
'17 Frontier Pro4x/CC/MT
j mcpheezy
U.S. - Louisiana
Posted: Feb 14 2008 at 12:48pm | IP Logged Quote j mcpheezy
Yeah your prob right, i have a haynes manual i just havent cracked it to much.  i will look at it later. thanks for the opinion.
i live in abita springs
'04 CrewCab XE
   :::MODS:::
- K&N Cold Air
- 5% tint
- Black Headlights
Posted: Feb 15 2008 at 4:57pm | IP Logged Quote lakota
j mcpheezy;
This will help you with using the manual...
HAYNES CAR REPAIR MANUAL - A TRANSLATION
Haynes: Rotate anticlockwise.
Translation: Clamp with vicegrips, then beat repeatedly with a hammer
anticlockwise.
Haynes: This is a snug fit.
Translation: You WILL skin your knuckles.
Haynes: This is a tight fit.
Translation: Not a hope in Hell, matey!
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start, now you
are looking at scary photos of the inside of a gearbox.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Try lots of heat, a tin of WD40 (catering size), or a ten
pound hammer.
Haynes: Retain tiny spring...
Translation: "Jeez! What was that? It nearly had my eye out!"
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers to
dig out that pesky bayonet part.
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead
are throbbing, then re-check the manual because what you are doing now cannot
be defined as 'lightly'.
Haynes: Weekly checks...
Translation: If it ain't broke, don't fix it!
Haynes: Routine maintenance...
Translation: If it ain't broke... it's about to be!
Haynes: One spanner rating.
Translation: Your Mum could do this, so how did you manage to botch it up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low,
tiny, little number... but you also thought the wiring diagram was a map of
the Tokyo underground (in fact that would have been more use to you).
Haynes: Three spanner rating.
Translation: But Bricks are easy to maintain right, right? So you think three
spanners has got to be like a 'regular car' two spanner job.
Haynes: Four spanner rating.
Translation: You are seriously considering this aren't you, you amateur!
Haynes: Five spanner rating.
Translation: OK - but don't expect us to ride in it afterwards!!!
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahaha!!!!
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on, swear at,
throw at the garage wall, then search in the dark corner of the garage for
it whilst muttering "bugger" repeatedly under your breath.
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are looking
at, then declare in a loud knowing voice to your wife "Yep, as I thought,
it's going to need a new one"!
Haynes: Carefully...
Translation: You are about to cut yourself!
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Adjust gap to specified distance.
Translation: Ha-ha - got you again - you can search this book forever and
you won't find it!
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark plugs removed.
Translation: However, starting the engine afterwards will be much harder.
Once that sinking pit of your stomach feeling has subsided, you can start to
feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Haynes: Pry away plastic locating pegs ...
Translation: Snap off ...
Haynes: Using a suitable drift ...
Translation: The biggest nail in your tool box.
Haynes: Everyday toolkit
Translation: Ensure you have an AAA Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Haynes: The bearing inner races can be released by applying light leverage.
Translation: There is absolutely no way those inner races will budge without
the application of a puller (which you haven't got) and a lot of swearing.
Haynes: Index
Translation: List of all the things in the book except the thing you want to do!
Haynes Manuals are (C)opyright of a very disturbed sadist
firedawg93
Posted: Feb 18 2008 at 2:50pm | IP Logged Quote firedawg93
Try disconnecting wire harness for trailer.
firedawg93
Back to Top View firedawg93's Profile Search for other posts by firedawg93
