Subject Topic: Starter Issues... Post ReplyPost New Topic
GSTtex
Posted: Feb 19 2008 at 7:24pm | IP Logged Quote GSTtex
Ok so I'm new to the whole do it yourself concept. I decided to change my oil in my truck (for the first time) and drained the oil and everything successfully. Now when it comes to taking out the oil filter, I thought it was the canister that was black, which turned out to be the starter. Sooo dummy me, took off the starter and all. Yea it didn't quite click till right after I took off the starter as to why the oil filter would be on the transmission..
To make a long story short, my buddy and I managed to get the starter all back together and back on. My only worry now is that I some how may have not lined up the gearson the drive pinion. Yet the starter screwed on perfectly, the whole nine yards.
Are there any noises I should be aware of if something goes wrong? Are there any indications of my starter somehow being destroyed and me not knowing it? Please help!!
2007 Frontier SE
1996 Spyder GS-T
Back to Top View GSTtex's Profile Search for other posts by GSTtex Visit GSTtex's Homepage
GSTtex
Posted: Feb 20 2008 at 4:45am | IP Logged Quote GSTtex
Ok well after hours of research and me feeling stupid, Ive discovered tat the starter only turns once, when you start and not continuously. So, that leads me to believe that the noise I think I hear is a figment of my imagination or something else completely wrong..
2007 Frontier SE
1996 Spyder GS-T
Posted: Feb 20 2008 at 4:31pm | IP Logged Quote lakota
Starter bad noises are loud grinding or a singing whine... Hope it's OK
thedave360
U.S. - Louisiana
Posted: Feb 20 2008 at 4:47pm | IP Logged Quote thedave360
You have a  lot to learn grasshoppa . But don't feel dumb, thats what these forums are all about...asking for help when you have reached the end of your knowledge.
The starter spins only until the engine can run on its own power, which might be about 1 second. If the starter is still engaged when the engine is running, you should hear a loud grinding sound. If you dont, then I would say you did everything right.
With all that happening, did you ever get around to changing the filter?
Shift_Your own gears
Baton Rouge, LA
'17 Frontier Pro4x/CC/MT
GSTtex
Posted: Feb 21 2008 at 7:58am | IP Logged Quote GSTtex
haha yea im good, the starter is fine. Yea im a grasshoppa, but not so much when it comes to DSM's.
I changed the oil filter.. hard to get to. more annoying than anything. I suspect the reason why i thought something was wrong is because i switched to synthetic oil, trucks gotta let it work through..
no problems anymore.. what a trip though, lol
2007 Frontier SE
1996 Spyder GS-T
thedave360
U.S. - Louisiana
Posted: Feb 21 2008 at 9:21am | IP Logged Quote thedave360
I have always heard that switching to synthetic is good but not if you this is the truck's first oil change (from the factory). Conventional oil produces enough friction to let all of the vital engine parts set correctly.  Im not sure how many miles you can go before you can switch to synthetic with a brand new truck, so you may be ok...but do your self a favor and look it up. It may save you some money in the long run.
Baton Rouge, LA
Chris6744
Posted: Feb 21 2008 at 10:38am | IP Logged Quote Chris6744
there are many cars now day that have synthetic oil from the factory. i switched my 07 to synthetic at 7 miles. its all a myth about setting it. and you can switch back anytime. im a tech at chevy just to let you know im not just making this up
GSTtex
Posted: Feb 21 2008 at 11:17am | IP Logged Quote GSTtex
Rest assured, it was not as soon as i bought the truck. I bought it new last Jan. I now have 13750 miles on it..
2007 Frontier SE
1996 Spyder GS-T
Boomer
Posted: Feb 21 2008 at 3:43pm | IP Logged Quote Boomer
Chris is right.  New ring technology does not require the breakin period.  That is why so many new vehicles now come with Mobil 1 from the factory.  I changed to it at 1000 miles and burn no oil after 4000 additional miles on the Mobil 1. Use synthetic and don't look back.  Ity's good for gas mileage and if you plan on keeping the truck a long time, it will be one of the best things you can do.  Mobil 1 5W-30 is sold by Wal mart in 5 qt containers for just over $21.  Use a quality filter like a Wix (Napa Gold) or a Mobil 1 or a Purolator Pure 1.  You can extend the drain intervals over regular oil and in the end it can actually save you money.
2007 Nissan Frontier SE 4X4
GSTtex
Posted: Feb 21 2008 at 6:20pm | IP Logged Quote GSTtex
yea i used mobil 1 oil and filter. how often should i change synthetic oil? every 5k miles?
definite difference, truck feels like it has more power, and is more responsive!
2007 Frontier SE
1996 Spyder GS-T
Page of 2 Next >>
