| Posted: Feb 25 2008 at 6:53pm | IP Logged
Sounds like some type of short or drain. This can be checked by looking at the drain on the battery as you pull and then replace one fuse at a time to find the circuit that is the culprit. You can then work on that circuit to find the exact problem. A good independent shop can do this type of analysis.
Check the obvious. Is there an interior light on when the truck is parked? Even something small like a glove box light will drain a battery. How about an underhood light? Are the brake lights off? Do you hear anything running like a small motor?
