toriolmo Newbie
| Posted: Apr 14 2008 at 2:26pm | IP Logged
I need some advice folks! New to these forums and new to my 2000 nissan frontier v6 4x4. It's been running hard shaking the whole truck especially at stops while the engine is still running. Sometimes it will even shut off. My bro suggested a tune up which is no problem for me to get done, but I took it to Advanced Auto parts and they gave it a diag and said it was a "knock sensor" and then another code said "system to lean". Super! What does that mean and what do I do now??? I don't think this is something I can take on myself.
Please some advice!
__________________ Tori
2000 Nissan Frontier V6 4x4
2006 Honda Rebel 250cc
Fort Hood/San Antonio TX.
thedave360 Senior Member
| Posted: Apr 14 2008 at 5:43pm | IP Logged
System too lean= the engine does not have enough fuel to run properly. It could cause the engine to run too hot, fowl out spark plugs and do other bad things.
Knock sensor= is a sensor that senses if the fuel in the engine is igniting before the spark plug fires. It adjusts the ignition timing to fix it the knocking.
You may have to replace the knock sensor if it is bad. I'm not sure if the knock sensor could make the engine lean. But the engine being lean could make it knock.
Never trust just the computer. Take out your spark plugs, if they are burnt white...you are running lean and the plugs are probably messed up. After you replace the knock sensor, I would suggest changing the plugs.
Baton Rouge, LA
'04 Frontier XE
2.4L 5speed
***MODS***
Flowmaster 40 Series Exhaust
APC Air Intake
Red Calipers & drums
4 Kenwood Speakers
Boomer Senior Member
| Posted: Apr 14 2008 at 6:16pm | IP Logged
Dave, just a small clarification. Knock is usually caused when fuel of too low an octane rating is used. The knock occurs AFTER the spark fires. The spark sarts to burn the fuel around the spark plug. This in turn raises the pressure extremely rapidly in the cylinder which in turn sets off the fuel right above the surface of the piston. This is really an explosive pressure-induced combustion in a second flame front which we hear as a knock. Higher octane fuels can resist this secondary detonation much better. So if the timing is retarded a bit, the pressure buildup is less severe and the lower octane fuel will not normally do this under the retarded timing conditions. The site below will show diagrams of this for both deposit-induced knock and compression-induced knock. Hope this clarifies knock.
It also helps to understand why higher octane fuel is a better insurance against knock than just depending on the engine retarding the timing.
Google Image Result for http://www.thor-racing.co.uk/images/what_is_detonation.jpg
| Posted: Apr 14 2008 at 10:31pm | IP Logged
toriolmo;
The knock sensor is #22060P same as the xterra
http://www.courtesyparts.com/betasite/frontier-d22u-1998-200 4/genuine-nissan-parts/engine-electrical/226-engine-control- module/-c-2129_2130_2160_2164.html
http://www.courtesyparts.com/betasite/knock-sensor-2000-2004 -xterra-p-104.html
Have a good New Year while you can still laugh about it.. Don S..
Laws such as the use of corn ethanol are driving up the cost of living (have you been to the grocery store lately) without driving up wages. This equates to a lower standard of living thanks to Agro-lobbyists and corrupt and ill-informed lawmakers
toriolmo Newbie
| Posted: Apr 15 2008 at 1:30am | IP Logged
Hey thanks you guys so much for your knowledge it is much appreciated. One question I must ask though. Should I change my plugs first then see if the sensor should be replaced or should I just do both. It's going to be hell if I have to change out the knock sensor so if I don't have to do it I really rather not. Thanks again!
Tori
| Posted: Apr 15 2008 at 2:59am | IP Logged
Google Image Result for http://www.thor-racing.co.uk/images/what_is_detonation.jpg |
Thanks for the info. I've never been really clear on the specifics of that.
So if Tori's engine is running lean, which makes it run hot and possibly make it knock (correct?), we need to know if the check engine light is because the sensor is bad or if the engine is knocking. I didn't think to ask that at first. No sense in buying a $150 sensor if its not bad.
If the code is just that the engine is knocking, there must be a reason...probably because its lean (unless its a S/C V6 which needs high octane). What sensor would make it the system run lean that would not trip a code?
Baton Rouge, LA
'04 Frontier XE
2.4L 5speed
***MODS***
APC Air Intake
4 Kenwood Speakers
| Posted: Apr 15 2008 at 6:35am | IP Logged
I think the two items that are most likely are the O2 sensors and the MAF unit. I don't know how far they can drift without throwing a code. personally, I would look at the O2 sensors. If they are some years in age, they do gradually deteriorate which usually shows up in worse gas mileage. However, withoout codes, you are in for a lot of expensive diagnostic testing. I would not go down the road of throwing in new parts, though, as that can be even more expensive, especially if you have a shop do it for you.
Lakota's part number for the knock sensor is good to have, however. You can save a ton by doing repacements yourself instead of paying labor. Perhaps the knock sensor might be a worthwhile replacement. O2 sensors are usually burned out after 8-9 years and are just reasonable replacements in a truck of that age.
toriolmo Newbie
| Posted: Apr 15 2008 at 10:09am | IP Logged
The codes I'm getting is P0325 knock sensor/P0171 system too lean.
| Posted: Apr 15 2008 at 12:03pm | IP Logged
Thanks for the codes. I looked them up. It does say that the P0325 is a faulty knock sensor circuit. So, most likely you need to replace that.
The P0171 system lean can (like boomer said) be caused by a bad MAF (Manifold Air Flow) or Oxygen sensor. I would start by cleaning the MAF with some throttle body cleaner. Remove it, spray it, let it dry and put it back. Also, (like boomer said) Oxygen sensors get old, so replace that if cleaning the MAF doesn't fix the lean mixture.
I had some problems a while back and I thought my MAF was bad. A new one was about $400 for my 2004 2.4. Thats why I suggest cleaning it before you decide to replace it. The oxygen sensor will probably be cheap though. Also, changing the spark plugs would be a good idea.
Good Luck!
Baton Rouge, LA
'04 Frontier XE
2.4L 5speed
***MODS***
APC Air Intake
4 Kenwood Speakers
| Posted: Apr 15 2008 at 1:33pm | IP Logged
... Always keep in mind when dealing with engine management and computer problems check the wiring plugs (first ) for good conductivity. Also recheck body, battery, and engine ground cables. A little corrosion goes a long way
It would be nice if our members would add their vehicle information to their signature (similar to mine) plus add their City and State . A member in the same town might be willing to drop by and help you with a problem. Or drink all your beer ...
