| Author |  |
        | imcbl Newbie
 U.S. - Ohio
          I have a 2001 Frontier.  My truck has a noticeable shimmy when it rains or when it recently rained.  Admittedly, my check engine light is on and I have not had it checked.  During dry weather, I do not notice any problems.
           | Posted: Jun 12 2008 at 7:14pm | IP Logged |   |
 I'm not very mechanical but I am willing to do some minor work.  A couple of years ago my dealership recommended I have the carbon cleaned from the engine and it was stupid expensive.
 I'm reluctant to go to the dealer again.  It seems that for every problem with the truck,  they have a $1000 solution.
 Any thoughts?
        | Back to Top |     |
        | JeffKyleMc Newbie
 U.S. - Alabama
          Is your intake hose on? if its not water may be getting slung up into the fan causing it to spray in the intake.  I have mine off but never have problems. But that was all i could come up with off the top of my head.
           | Posted: Jun 12 2008 at 8:50pm | IP Logged |   |
        | Back to Top |     |
        | Boomer Senior Member
          Wet distributor, wet spark plug wires (spray them with WD-40 during rain but before you drive to see if it eliminates the problem), wet ground connection somewhere that causes an intermittent "short" or voltage fluctuation.
           | Posted: Jun 13 2008 at 5:09am | IP Logged |   |
 2007 Nissan Frontier SE 4X4
        | Back to Top |     |
        | dannyg Senior Member
          Danny here check the PCV valve hose is hooked up Also check the valve pull it off the rocker arm cover and shake it if you here the check ball rattels than its good
           | Posted: Jun 13 2008 at 8:37am | IP Logged |   |
 06 frontier 4.0 auto
        | Back to Top |     |
