| Posted: Dec 28 2008 at 6:36am | IP Logged
A tip on a squeaky belt. The belt may be fine but getting just s bit hard on the rib surface. Take a few SMALL dabs of SILICONE grease (not oil-based grease) and spread them across the ribs with the engine OFF. Then run the truck. This will quiet belts and will not cause problems with the rubber in the belt. SIlicone grease is dielectric grease like you put on spark plug boots and is available at any parts store.
Also, DO NOT put the grease on the smooth side of a ribbed belt. This can cause tensioner slippage.
