| Posted: May 06 2009 at 6:20am | IP Logged
Go to AutoZone or any other auto parts store, they will read engine codes for free. This will likely point you in the right direction of what needs to be replaced.
Keep in mind, when one part fails, sometimes it sends off some false failures to the computer. For example, my codes read a failed knock sensor and low EGR flow, when the actual problem is just a failed temperature sensor.
A Hanyne's manual will list a number of diagnostic tests to run for various codes, usually only needing a multimeter and a few other basic tools. Do it yourself, and you'll avoid going to a dealership and spending big $$!
