surfahjammer Newbie
| Posted: Jul 01 2009 at 8:50pm | IP Logged
Wassup all I got an issue with my reverse lights they don't work. I just noticed it the other day. Here's what I did as far as troubleshooting. I put in 2 new bulbs,checked fuses and even tested if there was any power reaching the bulb sockets. There's no power in there. I checked wiring as far as I can see everything looks ok. ANybody know what the problem could be?
__________________ live to surf:) surf to live
| Posted: Jul 01 2009 at 11:27pm | IP Logged
surfahjammer:
You might try cleaning the sockets and all wire connectons. The salt in the ocean air can cause corrosion. Good luck!
I used to be quite indecisive but maybe now days I’m not so sure!
| Posted: Jul 02 2009 at 8:08pm | IP Logged
surfahjammer wrote:
Wassup all I got an issue with my reverse lights they don't work. I just noticed it the other day. Here's what I did as far as troubleshooting. I put in 2 new bulbs,checked fuses and even tested if there was any power reaching the bulb sockets. There's no power in there. I checked wiring as far as I can see everything looks ok. ANybody know what the problem could be? |
You might try letting us know what you are working on!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Not mind readers!!!!
surfahjammer Newbie
| Posted: Jul 03 2009 at 3:23pm | IP Logged
Good point frontierguy i've got a 2001 Frontier XE Crew cab 5 speed. And all the connections and wiring look ok as far as I can see.
Boomer Senior Member
| Posted: Jul 04 2009 at 6:23am | IP Logged
Could be the switch that is activated when you put the truck into reverse. Not sure where this is but they do fail.
surfahjammer Newbie
| Posted: Jul 05 2009 at 6:20am | IP Logged
Thanks Boomer anybody know where this switch is and what's it called. If I find it maybe I can test it with a multimeter to see if it's sending out any juice.
| Posted: Jul 07 2009 at 9:27pm | IP Logged
surfahjammer wrote:
Thanks Boomer anybody know where this switch is and what's it called. If I find it maybe I can test it with a multimeter to see if it's sending out any juice. |
It's on the trans -depending on 2 or 4 wd. turn your key on-unplug the switch on the trans -see if the lites come on. try each switch till you find the b-up switch.
surfahjammer Newbie
| Posted: Jul 08 2009 at 12:53am | IP Logged
Thanks frontierguy it's a 2wd. Anyone know specifically where it is on the trans? So if I put the truck in reverse,turn the ignition on and unplug the wires to the switch you're saying the reverse lights should come on?
| Posted: Jul 08 2009 at 9:15pm | IP Logged
surfahjammer wrote:
| Thanks frontierguy it's a 2wd. Anyone know specifically where it is on the trans? So if I put the truck in reverse,turn the ignition on and unplug the wires to the switch you're saying the reverse lights should come on? |
Had a brain fart. Turn the key on - unplug the switch- jump the wires together at the harness side of the connector. Does not need to be in reverse. You are by-passing the switch.
surfahjammer Newbie
| Posted: Mar 09 2010 at 10:11pm | IP Logged
< =text/>_popupControl();
Howzit all. I finally got to checking out my reverse switch. I unplugged it and jumped it. And yip my reverse lights went on. So I guess my switch is bad. I'm picking up a new switch tomorrow. Anybody got any special tips on installing the new switch? Thanks ahead all.
