Subject Topic: Squeek when driving on rough road Post ReplyPost New Topic
bogeysem
Canada
Posted: Jul 16 2009 at 5:43pm | IP Logged Quote bogeysem
Hi, I am wondering if anyone can help me as my dealer hasn't been able to!
I have a 2008 Nissan Frontier Crew Cab 4x4 which I have loved since purchasing it a year ago.  Problem is there is a squeek coming out of I believe the front end, when I drive in over bumps or down a rough stretch of road.  The dealer has replaced the sway bar bushings as apparently that was the problem, but the noise has persisted!  On the next service the adjusted the hood bumpers and greased somehow the bushings...the sound went away, but when i hit a rough stretch of road again, the squeek returned!  The dealer is now suggesting that the suspension will have to be taken apart to find the problem...does anyone have any suggestions or has anyone experienced a similar squeek when driving over rough roads?  The squeek is quite constant and annoying when driving over a bump or rough road.
Thanks
Back to Top View bogeysem's Profile Search for other posts by bogeysem
Posted: Jul 16 2009 at 8:52pm | IP Logged Quote frontierguy
There are 3 hood stops.  lube them and unscrew the center one for a tighter fitting hood.
Posted: Jul 20 2009 at 8:41pm | IP Logged Quote frontierguy
Had one in the shop today, found a squeak(over bumps) from the LF cab mount, loosened it , sprayed with penetrating oil, re tightened, squeak gone.
bogeysem
Canada
Posted: Jul 20 2009 at 11:24pm | IP Logged Quote bogeysem
Thank you, I will check both of those out and hopefully one will fix this anoyance.
Thanks
kavephish
Canada
Posted: Aug 01 2009 at 11:41am | IP Logged Quote kavephish
I have the same problem...
2006 Frontier SE Crew Cab 4X4
Back to Top View kavephish's Profile Search for other posts by kavephish
txjackash
Posted: Sep 29 2009 at 6:25am | IP Logged Quote txjackash
i have the same thing on my 08 4x4. is it something serious that i should get the dealership to look at? what exactly is an "over bump"? mine seems to be coming from the front right side of the truck.
Back to Top View txjackash's Profile Search for other posts by txjackash
Posted: Sep 29 2009 at 8:46pm | IP Logged Quote frontierguy
Bumpy road = rough road.
