mocheeks77 Newbie
| Posted: Aug 06 2009 at 10:37am | IP Logged
I have been having an issue with my 02 frontier (4 cyl). When I press the brake pedal all the way to the floor, my ABS light and parking brake light come on. If I only press the brake gently, this doesnt happen. Has anyone had this problem before or have any suggestions? When I turn the ignition off and start the truck back up, the lights are off, but as soon as I press the breake hard , they come back. Thanks for any advice.
davidjbrady Senior Member
Online Status: Offline Posts: 359
| Posted: Aug 06 2009 at 2:25pm | IP Logged
Any chance your brake fluid is low?
David
mocheeks77 Newbie
| Posted: Aug 06 2009 at 5:02pm | IP Logged
Fluid levels are fine, I'm guessing its a faulty sensor but I was trying to avoid taking it in for service. I was hoping someone on here would have had the same problem and could give me a heads up.
| Posted: Aug 07 2009 at 8:19pm | IP Logged
double check your fluid just to be sure. have you checked for trouble codes?
mocheeks77 Newbie
| Posted: Aug 08 2009 at 9:23am | IP Logged
Levels still look fine, but I dont have a diagnostic scanner. Thanks for the suggestions
