Stanmann Newbie
| Posted: Sep 13 2009 at 3:19am | IP Logged
I had a 05 Frontier and the left turn signal didn't work. Now I have an
08 Frontier CC 4X4 and there are no running/tail lights to the trailer.
Brake lights work, turn signals work but no tail lights. Is this a
common problem and what is the fix? I've checked all the fuses I can
find.
I have an appointment with the dealer to "find" the
problem, I ask if it's covered by the warranty. He say's uhhhhh, it
depends on what we find. This doesn't sound right.
__________________ 2008 Frontier SE Crew Cab 4x4 Silver
Boomer Senior Member
| Posted: Sep 13 2009 at 7:46am | IP Logged
Ddid you wire the truck yourself for trailer lights? If so, warranty won't cover it. If it is a factory job, they should cover.
| Posted: Sep 16 2009 at 8:37pm | IP Logged
Did you install the sub harness and relays in the right kickpanel?
