| Posted: Sep 25 2009 at 8:38pm | IP Logged
Seat/shoulder belts are lifetime warranted. There is a procedure for cleaning the "D" ring and applying special tape for proper operation of the shoulder belt, if that doesn't correct the problem, then it gets replaced. Classification:
RS01-001A
Reference
NTB01-005A
Date:
October 7, 2004
ALL NISSAN VEHICLES; "D" RING RESIDUE CAN CAUSE SLOW SEAT BELT RETRACTION
This bulletin amends NTB01-005. Please discard all paper copies of the earlier version.
APPLIED VEHICLES:
All Nissan Vehicles with front seat belt "D" rings
IF YOU CONFIRM:
Seat belt retraction of front seat belt(s) is slow, caused by "residue" build-up on the "D" ring(s),
NOTE: Slow seat belt retraction, if it occurs, may result in the following incidents after the seat belt is unbuckled:
Seat belt latch plate hanging up on clothing,
Seat belt latch plate becoming caught in the doo |
