nastymonte Newbie
Posted: Oct 25 2009 at 9:25pm | IP Logged
I am having a problem with a 2000 frontier that i am unable to communicate with the computer with my snap on solius or modius the only way I have been able to get codes out of the truck is with the cheap code reader. Which isn't terriable but I need to get data out of the truck to try to fix the check engine light. Does any one have any tips as to where I could start? I did make sure there is power to the DLC which I figured was ok anyways since the code reader powered up.
__________________ Mikey
Posted: Oct 26 2009 at 2:59am | IP Logged
do you have the correct personality key for the truck?
nastymonte Newbie
Posted: Oct 26 2009 at 5:53am | IP Logged
Yes I do
Posted: Oct 26 2009 at 4:45pm | IP Logged
Which DLC are you using? Seems like in 00 there were 2 DLC's, maybe not, I may be thinking of something else. Remove the fuse cover and see if the old style DLC is there.
nastymonte Newbie
Posted: Oct 26 2009 at 8:38pm | IP Logged
I was using the OBD II connector I will check and see if I can find the other connector I did find one on the schematic but could not find it yet. I pulled the connector off of the PCM and looked for corrosion or terminal push out and nothing yet
Posted: Oct 27 2009 at 5:32pm | IP Logged
nastymonte wrote:
I was using the OBD II connector I will check and see if I can find the other connector I did find one on the schematic but could not find it yet. I pulled the connector off of the PCM and looked for corrosion or terminal push out and nothing yet  |
The other style DLC should be behind the fuse cover- lower left.
nastymonte Newbie
Posted: Oct 27 2009 at 9:59pm | IP Logged
ok thanks
nastymonte Newbie
Posted: Oct 30 2009 at 8:34pm | IP Logged
Thanks everyone, I was able to comunicate and believe I found the problem, the IAC was sticking
nastymonte Newbie
Posted: Nov 01 2009 at 7:58am | IP Logged
Just wanted to post that I had a code in this truck for the idle circuit I believe it was PO505 I found the IAC valve was stuck, I took the valve and motor apart and the motor worked fine, but valve would not move . Broke the valave free and cleaned it up, and now it works fine and the light has not come back on atleast not yet
