| Posted: Jan 08 2010 at 8:03pm | IP Logged
Unscrew it!!!!! Are these the ones at the battery? May want to check the reason for it blowing unless you have already determined that. If I recall, there was a problem with the harness chafing near the battery tray and also on the brackets at the valve cover for the harness. Trying to picture the fuse, but the old mind is BLANK.< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
