Subject Topic: 2001 Frontier tailgate won’t open Post ReplyPost New Topic
paulsc
Posted: Apr 05 2010 at 11:43am | IP Logged Quote paulsc
I have a 2001 Nissan Frontier Desert Runner which has a locking tailgate. For some reason the tailgate won't open anymore. The tailgate handle is pulls up all the way easily but the tailgate doesn't budge when I try to open it. Does anyone know what I can do to fix this?
thanks,
paul
Back to Top View paulsc's Profile Search for other posts by paulsc
Posted: Apr 05 2010 at 5:05pm | IP Logged Quote frontierguy
Most likely it will need a new assy., unless you find something bent or disconnected.
paulsc
Posted: Apr 07 2010 at 3:46pm | IP Logged Quote paulsc
Thanks for the info. Is there anything I can do now to get it open?
davidjbrady
Posted: Apr 07 2010 at 10:41pm | IP Logged Quote davidjbrady
Not sure if you can use a credit card to shimmy the latches on the end of the tailgate?
08 Frontier CC, 4X4, LWB
dmartin16
Posted: Apr 08 2010 at 11:40am | IP Logged Quote dmartin16
I pulled the 2 bolts out of the back of the tailgate and just use my hand to open it up.. seems like the assembly is pretty cheaply made.
I figure, this gives me an excuse to get a new tailgate (mine is a little beat up)
But otherwise, yes, the assembly can be replaced, you just need small hands
2003 Frontier XE (Base)
Back to Top View dmartin16's Profile Search for other posts by dmartin16
pdhartog
Canada
Posted: May 19 2010 at 7:55pm | IP Logged Quote pdhartog
I had the plastic handle break off of that slab type locking tailgate.  Instead of buying a whole new assembly you can just buy the hardbody tailgate latch from 90's models and switch out the handle..... they fitBig smile.  All you have to do if hacksaw the pins on the new one and switch it out.
The Final Frontier
Back to Top View pdhartog's Profile Search for other posts by pdhartog
