altruism111 Newbie
| Posted: May 07 2010 at 5:27pm | IP Logged
Hello,
I have a 2001 Nissan Frontier 3.3L
The problem I'm having is that no matter what the a/c clutch stays engaged. I even pulled the a/c relay under the hood and it still stays on. The only way I can stop the clutch is by pulling the wire off the compressor itself.
What I have tried: Replace the A/C relay Replaced the a/c thermostat Replaced the ECM
Any ideas please??
| Posted: May 08 2010 at 8:04pm | IP Logged
If it stays engaged with the A/C relay removed, the green/black wire from terminal 3 of the A/C relay must be contacting another 12 v source due to chafing or pinched wires.
