Subject Topic: 1999 V-6 power loss/miss Post ReplyPost New Topic
bugman0914
Posted: May 28 2010 at 9:30pm | IP Logged Quote bugman0914
My 99 frontier is having a power loss/miss at low speed and sporadic.
Smells of gas. Codes read said Mass Air Sensor Replaced and cleared codes.
Check engine light again just say multi-cylinder failure. Runs out good at 60
and above. Any ideas?
Thanks
Tony Carico
Back to Top View bugman0914's Profile Search for other posts by bugman0914
Posted: May 28 2010 at 9:58pm | IP Logged Quote kcidmil
When was the last time it had a tune up, replaced all the spark plugs.  a bad coil could give you problems across all cylinders, or a bad distrubitor cap.
Posted: May 29 2010 at 8:47pm | IP Logged Quote frontierguy
Cap and rotor are a good idea, but most likely you have some plug wires shorting to ground. Try spraying them with some water to verify. Use Genuine Nissan wires, cap and rotor.
bugman0914
Posted: May 30 2010 at 7:57am | IP Logged Quote bugman0914
Thanks guys will check it out. Got up this morning, no check engine light on but rough idle. I have plugs need to get wires and cap and rotor! Power sucks and so does Gas Mileage!
Tony Carico
jgreenjr
U.S. - Tennessee
Posted: May 30 2010 at 8:44pm | IP Logged Quote jgreenjr
Also check sparkplug too while you are replacing the wire, my almost 20 years old  Toyota doing funny things so i replace both ! it much better ,i don't have truck anymore it been wreck since aug 2009 .
I love this 2003 Nissan Frontier !
Proud owner of
2003 Frontier
KA24DE
4 CYC.
4X2
AUTO
She don't love me ,but she loves my Automobile !
Jackie
A Proud owner of
2003 Nissan Frontier XE
4 cyl.
4x2
auto.
KA24DE
Stereo:Kenwood KDC BT648U
Ham radio since 2001 N4MJG
Tullahoma Tenn
Back to Top View jgreenjr's Profile Search for other posts by jgreenjr Visit jgreenjr's Homepage
