| Posted: Jun 04 2010 at 6:32pm | IP Logged
sounds like the wiring harness for your driver's door is frayed and shorting to ground.
You should see a rubber sleeve inbetween the front portion of the door and the vehicle itself when you open up the door. This sleeve should just pull out from the door and body. You can slid it along the wires and check to see if any insulation stripped away, or damaged wires.
