Subject Topic: Air conditioning high pitched squeal Post ReplyPost New Topic
janesvillite
Posted: Jun 29 2010 at 12:57pm | IP Logged Quote janesvillite
I have a 2003 frontier.
The air conditioning belts squeal like crazy when the compressor kicks on,
especially on hot days when I just start the truck. It doesn't squeal unless it's
over 2500 rpm or higher.
I have replaced all three belts, and even had a couple mechanics try doing
something. I'm wondering if this is a compressor issue, or something simple
that we have all overlooked. Any insight would be appreciated.
If it ain't dead, shoot it again.
2003 4x2 XE
Back to Top View janesvillite's Profile Search for other posts by janesvillite
Posted: Jun 29 2010 at 8:37pm | IP Logged Quote frontierguy
Are they GENUINE NISSAN BELTS????? Try spraying the clutch assembly with brake parts cleaner.
janesvillite
Posted: Jul 08 2010 at 11:22am | IP Logged Quote janesvillite
Yes I bought the belts from my dealer. After seeing my buddy but an OEM
belt and have it snap on the freeway, I learned his lesson for him.
I'll take your suggestion and let you know. Thanks
2003 4x2 XE
max2011
U.S. - Alabama
Posted: May 22 2011 at 8:19pm | IP Logged Quote max2011
I have the same problem. Any ideas?
Blessed to be a Blessing!
Back to Top View max2011's Profile Search for other posts by max2011
jgreenjr
U.S. - Tennessee
Posted: May 22 2011 at 9:52pm | IP Logged Quote jgreenjr
I replace my with  GENUINE NISSAN BELTS  from dealer !
Jackie
A Proud owner of
2003 Nissan Frontier XE
4 cyl.
4x2
auto.
KA24DE
Stereo:Kenwood KDC BT648U
Ham radio since 2001 N4MJG
Tullahoma Tenn
Back to Top View jgreenjr's Profile Search for other posts by jgreenjr Visit jgreenjr's Homepage
mmgearhead80
U.S. - Washington
Posted: Jun 01 2011 at 6:49pm | IP Logged Quote mmgearhead80
Mine did the same thing when I put new belts on.  The new A/C belt stretched quite a bit after a few hundred miles.  I had to re-tighten it twice, and that finally did away with the screech.  While I wish the 4-cyl had a serpentine belt with a spring-loaded tensioner, I now have the belt tightening procedure down to an art.
-Happy Frontier owner
Back to Top View mmgearhead80's Profile Search for other posts by mmgearhead80
