dahippiegirl84 Newbie
| Posted: Jul 08 2010 at 4:49pm | IP Logged
My check engine light has been on for a while. I took it to Advance Auto and got a 4th cylinder misfire code. I changed the plugs, cables and cap. Still got the code. I have an 02 Frontier 4 cyclinder manual. I've got about 120k miles and I put them on myself.
davidjbrady Senior Member
| Posted: Jul 09 2010 at 10:10am | IP Logged
Are you feeling a misfire at all?
Is it cutting out?
| Posted: Jul 09 2010 at 3:01pm | IP Logged
I am not feeling a misfire and it isn't cutting out.
| Posted: Jul 12 2010 at 8:02pm | IP Logged
Hopefully you used Genuine Nissan Parts!!!! Possible dirty or sticky injector, intake gasket, vac hose cracked??? The ECU can compensate for a slight vac leak making it challenging to find at times. Try spraying some carb cleaner along the intake manifold to head mating area to see if there is any change in RPM while spraying.
