rjbevan Newbie
| Posted: Aug 02 2010 at 6:24pm | IP Logged
2000 Frontier 4WD
DOES ANYONE HAVE A LINK TO AN ELECTRICAL SCHEMATIC FOR
THIS TRUCK?
When shifting into either 4WD Low or High, the fuse in
the panel labeled "meter" blows. It calls for a 10 amp
fuse. I just bought the truck a couple of months ago and
the guy I bought it from had a 20 amp fuse where the 10
amp should be. The 20 amp blew today when I tried to go
into 4WD. The odometer goes blank also and it wont crank
back up if you turn the truck off, unless you put it into
2WD High.
No schematic - No clue as to where to start looking.
THIS TRUCK?
HELP
| Posted: Aug 02 2010 at 8:40pm | IP Logged
Check the harness where it attaches to the trans and transfer assy. There are several rubber coated metal straps that tend to rub through the harness and short it to ground.
rjbevan Newbie
| Posted: Aug 03 2010 at 6:33pm | IP Logged
An earlier reply in the General Discussion forum suggested
that maybe the dash light that comes on when in 4WD was
shorting somewhere. This seems easier to check.
THANKS!
| Posted: Aug 04 2010 at 8:24pm | IP Logged
How is tearing a meter assy out easier than crawling under your truck and looking for something obvious that is a known concern????
Just checked your post in the General forum for the person that responded to your question, that explains everything!!!!!
rjbevan Newbie
| Posted: Aug 04 2010 at 9:13pm | IP Logged
Maybe I was unclear - sorry - QUOTE "an earlier reply in
the General Discussion forum suggested that maybe the
dash light that comes on when in 4WD was shorting
somewhere. THIS (i.e. - the harness where it attaches to
the trans and transfer assy) seems easier to check."
It would, in fact seem to me that it would be easier to
crawl under the truck and look at a harness that connects
to the trans and transfer assy than crawling under a dash
and sorting through a maze of wires in hopes of finding
what I need to check WITHOUT a schematic.
Sorry for the miscommunication.
| Posted: Aug 06 2010 at 8:23pm | IP Logged
That's cool. Have you found the problem yet????
rjbevan Newbie
| Posted: Aug 11 2010 at 8:01pm | IP Logged
Haven't gotten a chance to get under there - been out of
town - will do Saturday AM for sure. I will certainly let
you know what I find - hopefully It'll be the harness -
sure hope so. THANKS!
