alex973 Groupie
Online Status: Offline Posts: 61
| Posted: Feb 22 2011 at 4:28pm | IP Logged
i have service engine soon lights on, how to fix that? any help appreciated
my 06 NISMO is on 108K. what major service needed at this time?
any help is appreciated.
regards
__________________ alex06NISMO
| Posted: Feb 22 2011 at 6:50pm | IP Logged
Have you had it scanned for codes? Check your owners manual
for needed services.
Spiffy1 Newbie
| Posted: Mar 03 2011 at 4:46am | IP Logged
At what mileage did the light come on? Exactly 100K? If the truck doesn't have any issues with performance, idle, etc than it is most likely an O2 sensor. Not claiming to be an expert either. Also you can bring it to Pep Boys, Advanced Auto Parts, NAPA and they will check the codes for free so you can find out what the code exactly is and post it for further assistance. Once you have the code frontierguy will know what the problem is.
alex973 Groupie
| Posted: Mar 14 2011 at 1:16pm | IP Logged
the dealer said i need new cat, and it is big $1699 for one side
they delete the code so i did not see it. curtsey parts list the cat at
$500, evelbay has one for $118 which do i buy if that is the problem
does anyon have this done before?
thanks
alex973 Groupie
| Posted: Mar 14 2011 at 9:21pm | IP Logged
Hi Frontierguy, the service lights came on at 108k went to the dealer
??? what kind of aftermarket cat do you recommend? if it is the cat
that is giving the codes, evelbay or curtesey parts
price on evelbay is $118 and curtesey $520 dealer $1699 just one side
could there be a big price varience? thanks
| Posted: Mar 16 2011 at 8:21pm | IP Logged
The price is up to you, what ever you want to pay. The
other concern is whether or not the cat has come apart
which can cause a concern with the material being drawn
into the engine which will score the cyls and rings
creating a oil consumption concern.
NismoCab Newbie
| Posted: Apr 13 2011 at 3:49pm | IP Logged
Ive also had this same problem, with an 06 nismo
But I have also replaced both cats one with factor 1200.00 bleh and one aftermarket, 500.00. Both in the same year. March of 2010 then November 2010 plus the O2 sensors.
Well when I replaced my bank 1 cat back in Nov. (Nov. was the aftermarket cat) My service engin light appered once again after 2-3 weeks of driving. So I went back to the dealer, They stated since its an aftermarket cat the sensors will not read correct they are not designed to read aftermarket parts. So whats being stated is since I have to replace my bank1 cat with a factory part the process will be to destroy bank2 while removing bank1 then rebuild the system with new factory parts along with new O2 sensors x2 for a grand total of 2700.00. all this just to pass emissions even tho the truck runs clean. but in the county of maricopa in arizona if your service engine light is on it will not pass emissions.
has anyone else had this problem or know of an easier solution?
| Posted: Apr 13 2011 at 7:44pm | IP Logged
Why would it "destroy" bank 2 while removing bank 1????
That does not make any sense!!!!
NismoCab Newbie
| Posted: Apr 14 2011 at 10:08am | IP Logged
what I was told from the dealer, why im bring my concern to this forum.
| Posted: Apr 14 2011 at 7:45pm | IP Logged
It won't.
