Subject Topic: 2000 frontier crew 3.3L Post ReplyPost New Topic
doug12903
Posted: Mar 10 2011 at 12:40am | IP Logged Quote doug12903
i have 2000 frontier crew 3.3 v6.  The truck started running rough, tach jumps and cuts out at high rpm.  it will even stall out.  It doesn't do this until it has warmed up and run for about 20 minutes.  I checked the codes and I get a PO325 knock sensor code.  Can a bad Knock sensor cause all of this?  it almost acts like it has a rev limiter at high RPM.
dreynoldscdc
Back to Top View doug12903's Profile Search for other posts by doug12903
Posted: Mar 13 2011 at 2:43pm | IP Logged Quote frontierguy
Knock sensor will not cause this. sounds like dist is going
bad.
bplummer
U.S. - North Carolina
Posted: Mar 14 2011 at 10:32am | IP Logged Quote bplummer
Mass air flow sensor?  Mine was bad, causing the truck to run rough and stall out at low RPM, and "buck" @ higher RPM's.   When the sensor was tapped with your hand, the truck would sputter and stall out.....
Back to Top View bplummer's Profile Search for other posts by bplummer
