Subject Topic: blower motor resistor or worse Post ReplyPost New Topic
imne1
Posted: May 09 2011 at 8:35pm | IP Logged Quote imne1
2005 Frontier NISMO - 60K miles
I've read all the posts on blower motor resistors.  My symptoms are similar but just different enough for me to think it may be worse.
Symptons:
Blower setting: 1
A/C light comes on and compressor kicks in
No air flow
Blower settings: 2-4
A/C light will not turn on and compressor stays off
Normal air flow for setting
Can anyone confirm it is the resistor or something worse?
JC
Back to Top View imne1's Profile Search for other posts by imne1
Posted: May 10 2011 at 8:05pm | IP Logged Quote frontierguy
I would go with the resister, these newer ones do some
strange things.
imne1
Posted: May 11 2011 at 12:00pm | IP Logged Quote imne1
Changed the resistor and all is good.
Thanks.
safetyfirst
Posted: May 26 2011 at 9:05am | IP Logged Quote safetyfirst
strange things.
Had the same problem with my 06 Frontier, MT
Change the resistor all is good with the settings 1-4 but still no cold air.
I was told that my highside pressure was too high 400+, any change my expansion valve is done or worst.
Back to Top View safetyfirst's Profile Search for other posts by safetyfirst
Posted: May 27 2011 at 7:36pm | IP Logged Quote frontierguy
safetyfirst, I would recover the system to verify it isn't
over charged and verify the electric fan is operating.
