Subject Topic: 2009 Frontier SE Post ReplyPost New Topic
ranmcc
Posted: Aug 02 2011 at 8:18pm | IP Logged Quote ranmcc
I have a 2009 Frontier SE with 41000 miles.  Up until a week ago the horn would blow when I used the remote to lock the doors the lights also blinked.  Now the horn is not going off when you press the lock button.  Is there something I can do to fix this.  I changed the battery in the remote but that did not help.
Appreciate any help with this minor problem.
Back to Top View ranmcc's Profile Search for other posts by ranmcc
Posted: Aug 02 2011 at 9:00pm | IP Logged Quote frontierguy
Push the lock and unlock buttons on the remote at the same
time until the lites blink or the horn will blow, can't
remember which. Each time you do this, it will cancel the
horn or enable it.
ranmcc
Posted: Aug 02 2011 at 9:48pm | IP Logged Quote ranmcc
Thank you very much.  Good to know you can turn it on and off.  The remote is designed in a way you can set it off in your pocket.  Need to change the design.
ranmcc
Posted: Aug 03 2011 at 7:35pm | IP Logged Quote ranmcc
Worked perfect thank you very much.............
