Subject Topic: front hub 2004 4wd Post ReplyPost New Topic
dqnjuan
U.S. - Maryland
Posted: Aug 07 2011 at 4:18pm | IP Logged Quote dqnjuan
Just registered been a long time stalker for my 2004
frontier. Anyhow I was doing front and rear brakes along
with rotors today and I cant seem to get the from brake
auto hub back on without it making a clicking noise. I
think it may be from that o spring that holds on the very
front piece. Any advice?
Back to Top View dqnjuan's Profile Search for other posts by dqnjuan
Posted: Aug 09 2011 at 8:07pm | IP Logged Quote frontierguy
Once installed, rotate the axle by hand to see if the hub
disengages/ or engages. Once engaged, spin the wheel in the
opposite direction to disengage. Not sure what spring you
are referring to????
dqnjuan
U.S. - Maryland
Posted: Aug 11 2011 at 6:59pm | IP Logged Quote dqnjuan
It was a round spring going over the plastic clip, I ended
up breaking a tab off of and have to order another before I
used the 4wd. I did however get the new brakes and rotors
on atleast.
Posted: Aug 13 2011 at 8:05pm | IP Logged Quote frontierguy
How about a picture.
